This excellent power house of an air compressor sells for more than $5,000 new.
I’ll ship this anywhere but that will be extra, of course.
230V Input with nearly non-stop air output. This compressor has the upgraded system with water expulsion unit.
Perfect to drive heavy equipment, painting gear, and any other pneumatic equipment requiring an un-disturbed supply of air.
Growing demands on clean and dry compressed air, especially in dental and medical technology applications, are causing increasing demand for high-quality, oil-free compressors. The extensive and extraordinary JUN-AIR range continues the tradition: low noise, long service life and reliability. Minimal maintenance effort, an efficient cooling system and extremely wear-resistant piston rings enable continuous operation and min. 8000 operating hours.
All pressure vessels that are supplied in conjunction with an oil-free JUN-AIR compressor are coated with a powder coating to prevent corrosion damage.
JUN-AIR compressors are characterized by unrivaled low noise emissions.
This enables the compressor to be installed close to workplaces.
Technical specifications :
Suction power: 146 l / min
FAD at 8bar: at 8 bar 130 l / min
Max. Print: 8 bar
Motor power: 1.47 kW
Electr. Connection: 230 V / 50 Hz (suitable for 50 Hz and 60 Hz AC voltage)
Container volume: 40 liters/10.6 gal.
Noise emissions: 76 dB (A)
Duty cycle: 100%
Size W x D x H in mm: 556 x 443 x 678/Approx. 19"L x 18" W x 23" Tall
Weight : 59 kg /Approx. 130 lbs.
Asking Price: $2,000.00
Max. Print: 8 bar
Duty cycle: 100%
