Kai Vanuffelen
- Messages
- 1,278
- Company
- Kai Vanuffelen Pictureframer
Yesterday I was doing a speech at Toast Masters on conservation-glass to an audience of fifteen people, none of them being quantum physicists.
I did mention that the harmful uv radiation gets transformed into infrared radiation. If the uv radiation gets transformed into say green light, that we can see, the picture we look at behind the glass will probably look greenish. That is why the manufacturers transformed it into IR which we cannot see.
Fading depends upon the paint or pigments in the paint that the artist used. Ballpoint-ink will fade fast, whereas charcoal takes an enormously long time to fade. The substrate also matters. Newspaper turns yellow quickly.
I also touched upon radiation. My understanding of radiation is, that they are photons traveling at a constant speed. Not quite sure where the photons are in an atom, whether they are in the core with the neutrons and protons or further among the electrons.
The sun emits all types of radiation from short wave x-rays to long wave radio-waves. Some stars emit more of one type than another depending upon their composition and age. Apparently uv light can be altered into longer IR waves.
Gamma rays go right thru objects, whereas visible light shining onto an apple get bounced back.
Light can be bent as happens when one star moves in front of another star, so that we can still see the star behind the one in front. Light can be pulled back or held back from a black hole and probably light/ radiation/ photons emitted by one star can be trapped by a black hole so eventually as more black holes are formed, all light gets pulled into these black holes together with all other objects. This creates one giant black hole that at some stage bursts apart in a big bang, starting the whole process again.
I mentioned that the layer used by manufacturers either on one side of the glass or between sheets is made up of secret crystals.
Is there anything wrong with what I mentioned above, so that if I do a similar speech in the future I can adjust.
When seeing a picture of these intriguing black holes, they have spout at either pole. Are they releasing antimatter? This is something I did not touch upon in my speech, but maybe one of us knows.
