    You will have to register a free account, before you can access the system. If you have already registered, please LOG IN
Complete your certified picture framer test online CPF
FOR SALE Excellent Powerhouse Jun Air compressor
Thomas M. Houston MCPF
Master Certified Picture Framer®
Ashland, OR
Houston's Custom Framing
[FONT=&quot]This Excellent air compressor sells for more than $5,000 new. It's Jun Air!
We are selling this beauty for $2,000.00
Model #0F-1202.
[/FONT]You could run your whole shop with this; CMC, underpinner, air guns etc.
[FONT=&quot]230V Input with nearly non-stop air output. I bought the upgraded system with water expulsion unit.[/FONT]
[FONT=&quot]Perfect to drive heavy equipment, painting gear, and any other pneumatic equipment requiring an un-disturbed supply of air.[/FONT]
[FONT=&quot]Growing demands on clean and dry compressed air, especially in dental and medical technology applications, are causing increasing demand for high-quality, oil-free compressors. The extensive and extraordinary JUN-AIR range continues the tradition: low noise, long service life and reliability. Minimal maintenance effort, an efficient cooling system and extremely wear-resistant piston rings enable continuous operation and min. 8000 operating hours.[/FONT]
[FONT=&quot]All pressure vessels that are supplied in conjunction with an oil-free JUN-AIR compressor are coated with a powder coating to prevent corrosion damage.[/FONT]
[FONT=&quot]JUN-AIR compressors are characterized by unrivaled low noise emissions.[/FONT]
[FONT=&quot]This enables the compressor to be installed close to workplaces.[/FONT]
[FONT=&quot]Technical specifications :[/FONT]
[FONT=&quot]Suction power: 146 l / min[/FONT]
[FONT=&quot]FAD at 8bar: at 8 bar 130 l / min[/FONT]
[FONT=&quot]Max. Print: 8 bar[/FONT]
[FONT=&quot]Motor power: 1.47 kW[/FONT]
[FONT=&quot]Electr. Connection: 230 V / 50 Hz (suitable for 50 Hz and 60 Hz AC voltage)[/FONT]
[FONT=&quot]Container volume: 40 liters[/FONT]
[FONT=&quot]Noise emissions: 76 dB (A)[/FONT]
[FONT=&quot]Duty cycle: 100%[/FONT]
[FONT=&quot]Size W x D x H in mm: 556 x 443 x 678/18 x 19 x 23 tall[/FONT]
[FONT=&quot]Weight : 59 kg/approx. 130 lbs.[/FONT]
Welcome to Framers Corner
Picture Framing Magazine
