I agree with Cliff. I have never seen anyone marked down for information labels as long as they do not identify you or your shop. If you have a moulding company sticker with a location you should leave that off, it could identify the area you are from in a very broad way but it is identifying, same in your description do not say XYZ Company of Anywhereville USA, Canada, New Zealand or Australia ect... Just be sure your envelope is accessible. I have seen some that are hard to get into and the judges risk tearing up the backing on the frame.
Also be sure if you use something in the framing package tell where it was used and how, for example if you put ATG tape was it in the framing package or just on the dustcover? was it ATG gold or regular ATG? White glue, what kind, you get the picture never let the judges assume something is or isn't Acid Free.
As for the filler board listing, are you looking at Filler Boards and then Spacers/fillers? If so I would interpret this as Filler Boards - what is filling the back of the frame, if anything, and spacers/fillers is there a space between the glass and mat, or is there a space (buildup) between the mats or the mats and the item being framed, If so what did you use to make that happen. Some one else may have a different interpretation and will chime in. Hope this helps!
P.S. if it does say filler board twice it could be in the conversion over to a PDF it added it again? maybe? I'm not the best computer person I just muddle through, :smile:
Robin
