Ann Arbor MI Shop closing
Randy Parrish CPF
Ann Arbor Michigan
Parrish Fine Framing
I am helping a neighboring shop out, if you need details contact them directly
Frame Factory Ann Arbor MI
734-971-1100 info@framefactory.us
EQUIPMENT
$ 2,600 Pistorius Double Mitre Pneumatic Saw with Measuring Arm, Feeder Table, Extra Wood/Metal Blades
750 Jyden Mitre Chopper with extra blade set
5,500 Gunnar 2100 Computerized Mat Cutter, Production Grande 40x60/Stand/Operating Computer
450 Fletcher 60” Table Mat Cutter with Square Arm
950 Fletcher 60” Wall Mount Glass/Plexi/Board Cutter with Measure Arm
450 VacuSeal 3444H Heat Press with Stand
1,600 Corona Site Mount Heat Press 40x60 48”x65”
650 Removable Work Top table/stand for 40x60 press, with Foam Board Storage beneath 51w x 8’ x 37”t
990 AMP VN2+1 Pneumatic Underpinner with custom fit work table and bench storage below
495 Electric Thumbnail Router
650 Silent Aire 50-24 Compressor
75 Attach-EZ Mount Starter Kit with instructions/video
25 ea Shop Vac and Front Carpet Vac
50 Dust Collector for Saw
35 Logan Disk Sander
FURNITURE/FIXTURES
Front Room
$ 195ea Front Work Counter – 4 10-drawer Flat Files, 45w x 36”d x 33t (drawers are 2.25” deep) 4 Available
350ea Metal Flat File Storage: 3 5-drawer units, 43w x 32d x 51t (inside drawers are 40w x 30d x 2t) 3 Available
350 Checkout Counter/Register/Electric Hookup 94w x 23d x 42t
250ea Wood Veneer Slat Display Stand,2-sided 50w x 26d x 60t 3 Available
200ea Wood Veneer Shelves/Drawer Display Stand 45w x 16d x 76t 2 Available
50ea Glass Jewelry/Gift Case 15w x 14d x 64t
250 Cherry wood and Glass Lighted Tall Display Case 48w x 24d x 80t
125ea Spinner Corner-Sample Racks, 30”w x 80t, 4 Sides 3 Available
75ea Three-sides Corner Sample Racks on Wheels, 18” x 70t 2 Available
50 Artprint Rack 40x60
150 Office Desk/Chair/File Cabinets
70 Matboard Cart
15ea Metal Wall Grid, Black 2’w x 8’t 6 Available
Back Room
450 Work Table with Vertical Sectional Storage Rack Beneath 12’w x 4’d x 34t
350 Work Tables with Vertical Mat Storage Compartments Beneath 8’w x 4’d x 34t 2 Available
350 Glass Storage Rack 8’w x 4’d x 4’t
150ea Moveable Work Tables (with wheels) One is 33w x 40d x 36t , the other is 36w x 48d x 36t
Also Available: Nielsen Metal lengths, Wood length, Assorted Glass, Foam Board, Matboard
Security Hardware, Screws, Hooks, Wire, Offset hardware, etc
FRAME FACTORY - ANN ARBOR: FIXTURES AND EQUIPMENT 734-971-1100info@framefactory.us
MwxxTVyKVB32cRbt_liSZIG3cqRGtOrkaCA5p_e6-neq67y9DD2SxK37X7dsxQMly8Tf2n-CKlDP-EQwlY4fbt_AGjlw0dvguo18heywdkZtjYQH2TjUimH4u6eWhlm7FdOJFvDRmitAqAbn
no1miovG1ACYHirmE2YW35LdYKUIeMdvWS2SYh5hpXsxcIHSaMDux06Z0t9jufJqUw9p5fxo_VbU1bCxUu7h8eOLnAMzl14vYFuxLlr5BdycgCwAWDBvuBkVSHwzwq_xeFaNLp5O_YadNLks
T-3f7QCcduZJdLazDr_f3uBrNeUhZoCl1jPsH_ykxTLfjMmambe0p7M2DRg1OzxrHGnIuQ4o4HYFxqxy_YWStQulEGOlbYYdNhjvabLSTyTSgiHX4_Hz_eF5YKmXyP67Ak8fe2TQf-sqcWFK
Check Out Counter – 23w x 94long x 42 tall with shelves and storage drawers Wood/Glass/Lighted Display
yHCMX23NslDWWC9lynATtXG9ZTYN6Q5QPnaywrImKoIODcWe3tVuudCYk0t2KlIA7nWmdQWQ6Gmk_p2Zqz3r6CJAby41ZOa1MthkzA1IjByAFhwi1le5ZVE_dgMtzTJK8ymfQh2eXQGaebcU
iPqVX_mkr6vZZWxVi9j0pJOjsn2Ua33yC38OOshTaUEn5h_JrPxJVhFbyr4jLH-xXZ_TG1lk5iDMFAkDJYZpG8I08BeCB_ZR6gcUenaLTk-Bhi3xveaWntFleKv6gXI1HRdyufOep9ZQqUHr
xBCz72MXtUmevIJ_ml7l7uyfhfpFdqCdZL6fXQeeB53LSmwOeFobYy09hNbjMMuYfyOGK_JHTIx-_SJ9Z3BS9z9lqUYulEODd5_vRATC9_3tk8aOjwyHTpHfap9IeFXBx75LNjiFUqAlT8As
Glass Display (6)Front Work Counter – made up with 4 Flat Files
Xm-Yggq7ntsswoEqzudcxn1MTVNa2thJfNfJLrJr7j8JyLQQat7aGHvD3kSXV80PLPdBBH_i1Ilbz2uEc5smBsJELZvFIJ8Wl1kug-Zvb7t-b_FwdcoukzkxpuqR2da-xEwoUJF9WZYKT-OM
ONQ0V1haL0MmJO-wd3xHfYU719Md75yrve8kjlXznJ9V1Rr-LfsYtP_WJeV5opWToWPZCXzsQkT8JpbyI1pTfQZ7LXOwBWHKztGVH1gliuuCp7e8zi-g-XQddlhdCswLtNuMJmpZCnhafSqm
Veneer Wood Display Cases (Italian Made) Three with two-sided slat, Two with Shelves/Drawer Closeup Photo
u1cBlIv-O1N7CrmUQFtZF6nzH7cFv0NZQ3EXl-PDmSE9KRue2orpq6a9x6Y_7MamnxLz5DPb62U_EViYkiLg1wZU1-_nbBMyk6rP2_gedvGqrduJIdSMTuEB3J1_rIkQn8b_wtHSkn31L4SJ
2jWPcbd6rXeEoy3V2D3HUmbHdwhBFPrB7QPCJWufInop740kIEpM7fPVv4yQeuXoxdcKspd-59ugDlTh3Agx7eYz77ESRiPfCfCL3_UQrJz5ZcLOR9VgyEwBATpSBasVwQcy8gZaY5Wxl4mQ
Display Fixtures, store view
6CwrZrIK1aZgRquzZM8Ju6ei0K8GgG5u5wJ3zCGSgcp7EDpY1_0xlRCuuk15A-zkAia_ub2oWIbb8VuTeJDHee-PfMNGc8LSu9HlPvJ0w_OIBfyoNKHuLAf_oZkYRjTiltM9974R4jtalPMx
0FXlmpeGyr_h3X7Dw2YYV3Da8W_Q_NLUw3juoCGLwc48w4ax24wCK654NTFW28l_BDdtC16Q-QvbBK9P8VZITfwub8Ml1amZzTI90IDlXGlTpwumg-ZJFy08owpH4VdOFitq27pSCEBIN-VM
Fletcher 2100 60” Table Top Mat Cutter 4 x 8’ work table w/Mat Storage 2 Available
JKu20KMBlqgGJuVZPOa9IP_YwFmVMdhoyDpAWpsnphrms6CviF3htConucKkIbnhZW96bCR7qdK824YDrMay8SjcGac8bpKAHcUcYIsp2ROnocJlRKcx1Jk6uKRkOrTovEkIPGH_c_JEupFT
xaRbMZ-XMEdh1kWooARRjnaD19KycLxy462E6jaahejz0LyrFnF3IBeACRTEUmamMYlbSI8cFQddsx4Zp4RqnMTWv6Zx3WFgDabBArftE_ugEqot0K8cvJ20QTEdmf5jp-VbFel3L6yc-qEt
Corona Site Mount 40x60 with Custom Work Table VacuSeal 3444H with stand
Table top sections come off when press use is needed
l-BXuOwmFYcQmAjPRqQliRNkdG0IvqeqNM5JXCxm8W-c_Se3qkgXRdLRcLW7rn-M31h4hGHJP-ZbwETQwuxkxp7hYmshgVWwDuTmMXsEKKCQIpj8Sqc0xW2-_tW3VXlVwUMfKXC8Mkh13AWx
l-kq1dU7QhzE1GacQ5YXfb3Edh2DgeHpcvhy5iEo4QfluBGfXwoP3iPz8cdo6V72oFf8RkRG687YysGG_I0Enmfa7RZIIuoxctQN5iI0xCAlW-WK6IIx47qhxE_E08LnKPLTj2fCfIazqVBH
Pistorius Double Mitre Pneumatic Saw with Guide & TableJyden Chopper with Measure arm
OFM2_FBHxUVoGS3tjC-dijU2ZdxRFDLFZUBvZYbpR4yXR43mxwmGk4NQXQQQmd0y6vRz7l0G-dt61VXsu8GDcVDXeCiIgDbfGU9GixLxV1bSgRYRUqRHHZNZnMjPUcqTep5NeKmsUYU-jPqh
AMP VN2+1 Underpinner with Custom L-Shaped Table
Moveable Table (with white cover) is used to support frame back during join
kg5RYyEKlhh6kvW7mLgy73vR9vWGAIcO-iLLeDKB4CU9UOgRD_dzfQMgWYpJCY8EA-dkHgbOhvilxQo2r9sy4PP90orneYc7ja442_NJlzWljiHCFUIAmgtD6zBDIrhVVyMjF9aJ38foon-L
EVOUskErCmTUG4fj51Rl8kp3kwEQURBWJMqmj35B9-P1K-cvLqv9wUE1lQOTnxzb2aMjYz8LiN_OwAoMHvWBJywW7m7YgihMBqMXyvn_TFT2aQYXYmX6-Fd5MpXI3bC5Q64KiOb08Ll1DSz1
